CCR 1036 DHCP Snom Phone permanently rebooting
since I setup the DHCP Server on our Router we have permanently the issue that some IP Phones permanently rebooting. Today I have a couple of Snom phones with this issue. Last week I had a bounch of Aastra and Avaya IP Phones with this issue.
Normally I have to reboot the router to fix this but this can’t be the solution.
/ip dhcp-server> print detail
0 name=“dhcp1” interface=ether5 lease-time=14w2d address-pool=VoIP bootp-support=static src-address=10.230.250.1 authoritative=after-2sec-delay lease-script=“”
Suggestions are realy welcome.
regards
Maedo
11:54:55 dhcp,debug,packet dhcp1 received request with id 3417708981 from 10.230.250.96
11:54:55 dhcp,debug,packet ciaddr = 10.230.250.96
11:54:55 dhcp,debug,packet chaddr = 00:04:13:77:1B:31
11:54:55 dhcp,debug,packet Msg-Type = request
11:54:55 dhcp,debug,packet Parameter-List = Subnet-Mask,Router,Unknown(4),Domain-Server,Host-Name,Domain-Name,NTP-Server,Vendor-Specific,Address-Time,Unknown(6
6),Unknown(67),Unknown(120),Unknown(125),Unknown(132),Unknown(133)
11:54:55 dhcp,debug,packet Class-Id = “snom720”
11:54:55 dhcp,debug,packet Host-Name = “snom720-771B31”
11:54:55 dhcp,debug,packet Unknown(125) = 00-00-0D-E9-19-01-06-30-30-30-34-31-33-02-06-37-37-31-42-33-31-03-07-73-6E-6F-6D-37-32-30
11:54:55 dhcp,debug,packet dhcp1 sending ack with id 3417708981 to 10.230.250.96
11:54:55 dhcp,debug,packet yiaddr = 10.230.250.96
11:54:55 dhcp,debug,packet siaddr = 10.230.250.1
11:54:55 dhcp,debug,packet Msg-Type = ack
11:54:55 dhcp,debug,packet Server-Id = 10.230.250.1
11:54:55 dhcp,debug,packet Address-Time = 8640000
11:54:55 dhcp,debug,packet Subnet-Mask = 255.255.255.0
11:54:55 dhcp,debug,packet Router = 10.230.250.1
11:54:55 dhcp,debug,packet Domain-Server = 89.246.64.8,62.220.18.8
11:54:55 dhcp,debug,packet NTP-Server = 10.230.96.1
11:54:59 dhcp,debug,packet dhcp1 received request with id 3417708981 from 10.230.250.96
11:54:59 dhcp,debug,packet ciaddr = 10.230.250.96
11:54:59 dhcp,debug,packet chaddr = 00:04:13:77:1B:31
11:54:59 dhcp,debug,packet Msg-Type = request
11:54:59 dhcp,debug,packet Parameter-List = Subnet-Mask,Router,Unknown(4),Domain-Server,Host-Name,Domain-Name,NTP-Server,Vendor-Specific,Address-Time,Unknown(6
11:54:59 dhcp,debug,packet Class-Id = “snom720”
11:54:59 dhcp,debug,packet Host-Name = “snom720-771B31”
11:54:59 dhcp,debug,packet Unknown(125) = 00-00-0D-E9-19-01-06-30-30-30-34-31-33-02-06-37-37-31-42-33-31-03-07-73-6E-6F-6D-37-32-30
11:54:59 dhcp,debug,packet dhcp1 sending ack with id 3417708981 to 10.230.250.96
11:54:59 dhcp,debug,packet yiaddr = 10.230.250.96
11:54:59 dhcp,debug,packet siaddr = 10.230.250.1
11:54:59 dhcp,debug,packet Msg-Type = ack
11:54:59 dhcp,debug,packet Server-Id = 10.230.250.1
11:54:59 dhcp,debug,packet Address-Time = 8640000
11:54:59 dhcp,debug,packet Subnet-Mask = 255.255.255.0
11:54:59 dhcp,debug,packet Router = 10.230.250.1
11:54:59 dhcp,debug,packet Domain-Server = 89.246.64.8,62.220.18.8
11:54:59 dhcp,debug,packet NTP-Server = 10.230.96.1
I cannot see why dhcp would cause a voip phone to reboot.
For voip, try setting your ip’s as static.
Will solve most of your voip issues
Hello and thank you!
Unfortunately I have to use dhpc for 3 different types off IP Phones…
I searched several forum post and found inside the cisco forum a post which explains and solved my issue en detail.
Actually I installed 4 subnet on eth05 including the DHCP net, I moved the DHCP server on eth06 and the scope also on eth06. After doing this the phones are working without issues.
But I must confess this was really new to me.. I never had this issues with DHPC inside a small Lan enviroment.
However thank you for your replay!
Maedo
