Yes I agree but it also very important that we the users of Mikrotik products can view potential issues being posted and that the questions are answered by Mikrotik, this way we as users can gain more knowledge of the product?
@morf
I note your script for “Free Memory” and it reminds me of the script that would reboot router on high average CPU load, which only worked occasionally as with high CPU load, the average count (no matter how much I edited the number) would not complete sometimes and the router would just hang, I hope with memory it more successful?
And then there is this phenomenon, that if somebody finds a bug, they think that everyone is affected by this bug, and everyone knows all details about it
And one more phenomenon - if bugtrackers are publicly available there will be whole movement of "me too"s that in fact doesn’t have this problem, it is same like with diseases, more you read about them more you think you have one .
It’s good.
First of all I want to say that I am a big fan of mikrotik.
So perhaps it makes sense to give access to it as “authorized” user mikrotik. Or something like that.
*) pptp, l2tp - fixed crash when tunnel mru was too big and fragmented ip packet
was received;
*) hotspot - fixed problem when after upgrade hotspot html directory was empty;
*) ipv6 nd - dns dynamic-servers were not included in router advertisements;
*) winbox - fixed problem Switch menu disappeared on RB2011;
*) fixed memory amount issue on RB1100AHx2;
*) console - ‘/import’ prints each command that is executed;
*) console - ‘import’ has new argument ‘from-line’ that starts executing
commands after specified line;
*) secure api - fixed problem when wrong client ip address was reported;
*) hotspot - fixed universal client;
*) api - added support for API over TLS (SSL);
*) api - api service is now enabled by default;
*) ppp - do not show R flag for locally authenticated users;
*) vrrp - fixed ah authentication;
*) webfig - added support for RADIUS authentication (via MS-CHAPv2);
*) ipsec - for peers with full IP address specified system will
autostart ISAKMP SA negotiation;
*) trafficgen - added inject-pcap command for replaying pcap files into network;
*) dns - retry queries with tcp if truncated results received;
*) improved queue statistics updating;
*) fix 1G linking with some Cisco devices (affects RB7xx, RB9xx, RB1100, RB2011, CCR);
