Hi all,
I’m planning the expansion of my network and I’m looking at the CCR series.
The requirements are:
- ~ 400 layer 7 firewall rules (access blocks to specific domains (they have floating IPs, so can’t be filtered via IP firewall))
- ~ 350Mbps uplink to the ISP.
Which CCR model do you suggest? Will the CCR1036-8G-2S+EM ( http://routerboard.com/CCR1036-8G-2SplusEM ) be sufficient?
Any answer from the mikrotik stuff will be really appreciated!
Regards,
Thanos
