Hi All,
hope this is the correct sub-forum for my thread.
I’m having problems with single TCP-Connection uploads via SFP-WAN, tested it on two different Mikrotik devices (CCR1009-8G-1S-1S+, RouterOS 6.37.1 and CRS125-24G-1S-IN, RouterOS 6.36).
I do have a symmetrical 1GBit/s internet connection via BiDi Fiber and I tested with two different transceivers:
- Flexoptix S.B1312.10.DL-MSA01
- TP-Link TL-SM321B
I’m getting the same results with both transceivers.
Debugging this issue was quite hard, but my neighbour is connected to the same ISP on the same POP, just with different hardware.
We tested this using multiple methods:
FTP-Upload to a specific speedtest.tele2.net Server (fra36-speedtest-1.tele2.net):
- My upload speed: ~2MB/s
- My neighbours upload speed: ~30MB/s
Traceroutes to this server are exactly the same from both our connections.
iperf to our ISPs server:
- my speed: ~300-400Mbit/s
- my neighbours speed: ~900Mbit/s
iperf to another external server:
- my speed: ~70Mbit/s
- my neighbours speed: ~600Mbit/s
We tested it using IPv4 and IPv6 with the same results.
Speedtest:
speedtest.net results show ~950Mbit/s in both directions, as they are using multiple connections.
Furthermore I asked two friends to download a 2GB file via HTTP/HTTPS from one of my servers. When using one single connection for download (e.g. downloading with their browser), they could download the file with 10-16MBit/s. When using jDownloader with 20 concurrent connections on the same file, they maxed out their 100MBit/s download speed.
Today I bought a TP-Link MC220L Media-Converter, created a new Bridge-Interface on the CCR1009 (sfp1+ether7), changed FW-Rules/TrafficFlow/DHCP etc. from sfp1 to the new Bridge-Interface, removed the SFP transceiver from sfp1 and connected the Media-Converter via ether7. Now everything is working as expected. I get the same upload speeds as my neighbour, my friends can download with full speed on their 100MBit/s connection via a single HTTP-Connection - and I’m kind of speechless.
I really do not have any idea what the problem could be. There isn’t much you can configure on the SFP interface. I left the MTU-Settings untouched (actual: 1500, L2 MTU 1580), no bandwidth limit, SFP Rate Select: high (tried both), Flow Control: off (tried both), Auto Negotiation: on, Loop Protection: default.
I hope someone has an idea what the problem with the SFP-Interface could be? Or if something else could cause these problems?
Thanks a lot in advance,
j
