I want to do the following:
CCR = Main Router, connected via PPPoE/DSL as main line
LtAP = LTE-backup
How can I implement that:
- the the CCR checks if DSL is offline and switches over to LtAP automatically
- the LtAP itself should be a normal client and go out via CCR (DSL) unless DSL fails
Is the a guide how to do that? Thanks
You could use OSPF, and set a higher metric on the LtAP.
(both on local route table via pppoe client config, and OSPF)
OSPF metric setup is non obvious (v7)
Part example is:
http://forum.mikrotik.com/t/v7-ospf-default-route-metric/154003/1
Mine wound up as:
/routing filter rule
add chain=ospf-metric rule=“if (dst==0.0.0.0/0) {set ospf-ext-metric 20; accept;}”
/routing ospf instance
add disabled=no name=default-v2 originate-default=if-installed out-filter-chain=ospf-metric redistribute=static,vpn,dhcp,modem
router-id=x.x.x.x
