I just recently started using tools like ntop to do traffic analysis of the traffic flowing through my core router. I had originally planned to use port mirroring, but by core router is a CCR1036 and I realized that without a switch chip, it is unable to perform port mirroring. I found the recommendation across the mikrotik forums and mikrotik documentation was to use the packet-sniffer’s TZSP streaming feature as an alternative. (http://wiki.mikrotik.com/wiki/Manual:Tools/Packet_Sniffer#Example)
This is working great: I am streaming all my ~150Mbps of traffic to my analysis server, and the performance load on the router is impressively low! However, I’m finding that the streaming periodically disables itself…something like every 1-2 days I find that the analysis server just stops receiving traffic. When i login to the CCR1036, I just find that packet-sniffer is “stopped”. I restart it, and everything goes back to normal until it happens again.
I’m not finding anything in the logs, or any error messages that indicate why it’s stopping…so I don’t really know where to start trying to troubleshoot. Has anyone experienced this before and been able to resolve it? Any suggestions greatly appreciated!
I don’t know why the packet sniffer stops, but when you only want to do flow analysis (like ntop) wouldn’t it
be sufficient to use “traffic flow” instead of “packet sniffer”?
However if you are sure you need the packet stream to be mirrored, consider using /ip firewall mangle rules with action=sniff-tzsp instead of sniffer. You can find more info here.
Can you comment on any performance difference between using tool sniffer for the streaming and using the mangle rule for this?
Also - regarding traffic streaming vs netFlow…I think that the L7 analysis capabilities of ntopng are less if ntopng doesn’t have access to the full traffic streams, is this correct? I have tried a similar setup with netflow before, and I believe I am seeing much better identification of traffic with streaming than I was seeing with netflow.
I expect it to be the same, but I have never really measured it myself.
I guess that’s correct, though an important question is which exact L7 details do you need? Keep in mind that NetFlow reports different amount of data depending on the NetFlow version you choose (Mikrotik supports v1, v5 and v9).
Netflow provides only the peer addresses and port numbers, and the amount of traffic for the session.
It cannot peek inside the session to see what is really going on.
So a port 443 session will always be identified as https even when in reality it is something completely different.
Software that looks at the actual session data can do a better identification, but of course at the price of requiring
much more processing and load of the network between router and analyzer.
Yes - this is what I thought, thank you for confirming pe1chl.
Doing only “known port” analysis leaves out a lot of powerful tools to identify the protocols and applications being used. For example bittorrent and other p2p protocols that don’t stick to known ports will be identified by L7 analysis tools in ntopng, which wouldn’t be possible with netflow.
Hi, I have same problem with packet sniffer, but in my case status of sniffer is running but stream doesn’t go. Mangle is not solution for me, because I need only packet headers, with mangle this is not possible.
