CCR problem
Hello
I have got CCR1016-12S-1S+ router.
Sometimes when i reset it do not start and on lcd screen only info load from nand…
How can i do netinstall?
loading kernel from nand… OK
setting up elf image… OK
jumping to kernel code
(0,0) hv_panic: corrupt hvfs: computed CRC 0x3202b038, trailer CRC 0xa90a6ba7
(0,0) hv_panic: fatal DTSB read miss, fault addr 0
(0,0) fatal: invalid CPA for page 0
(0,0) Saved register dump:
(0,0) r0 0000_0000_0000_0000 r10 ffff_fffd_0000_0000 r20 0000_0000_003c_0780
(0,0) r1 0000_0000_0000_0000 r11 0000_0000_0000_0000 r21 ffff_fffc_0002_b5a8
(0,0) r2 ffff_fffc_0003_2708 r12 ffff_ffff_ffff_ffff r22 ffff_fffc_0002_b608
(0,0) r3 ffff_fffc_0010_e7f0 r13 0000_003f_fff0_007f r23 ffff_fffc_0002_b5a0
(0,0) r4 ffff_fffc_0004_3680 r14 ffff_fffc_0013_0abe r24 ffff_fffc_0010_e6a0
(0,0) r5 ffff_fffc_0012_a550 r15 0000_0000_0000_0061 r25 ffff_fffc_0010_e688
(0,0) r6 0000_0000_0000_1000 r16 0000_0000_0005_fcb9 r26 ffff_fffc_0010_e690
(0,0) r7 0000_0000_0000_0080 r17 0000_0001_bbdc_cfb0 r27 ffff_fffc_0010_e658
(0,0) r8 0000_0000_0000_2600 r18 0000_0000_0000_000f r28 ffff_fffc_0010_e650
(0,0) r9 ffff_fffc_0016_3018 r19 0000_0000_0000_0005 r29 ffff_fffc_0010_e660
(0,0) lr 0000_0000_0000_0000 sp ffff_fffc_0003_3808
(0,0) im 0000_003f_fff0_007f ex0 ffff_fffc_0000_61a0 ex1 0000_0000_0000_0003
I have the same issue with 3 Router’s CCR1016-12S-1S+
RouterBOOT booter 3.22
RouterOS version 6.29.1
Do you could resolve the issue?
I have the same problem, too.
CCR1016-12S-1S+
RouterBoard booter 3.22
RouterOS version 6.27
You have to upgrade firmware.
Power router on, upgrade RouterOS to the latest version and run “/system routerboard upgrade”. After reboot new firmware will fix this issue. If error is shown every time and you can not power device on, then try to power router on while reset button is pressed.
