And you’re sure it’s not power-related, right? (you didn’t mention that)
Also check for scheduler jobs.
Otherwise, look to see if autosupout files are being generated… if not, then turn that on and see if you get any crash files that you could send to support.
CPU reaches to 90-95% when this issue occurs. When checked interface, I can see lot of traffic (150-200 meg) on lan side where users are connected. Rx of lan is about 150-200 meg but Tx of wan is normal. That means MT is not forwarding that unwanted (flooding) traffic to wan side. But CPU utilisation is very high and BW consumption comes down from 400-500 meg to 70-80 meg. This could be some kind of flood from users on lan side. Have setup DDoS rules but they do not take care of attack from lan side. At the same time this happens with other 2-3 CCRs but they don’t reboot. BW utilisation comes down significantly though.
Can you analyze access level? 150-200mb/s not problem for ccr. Analyze connections tracker! Any log items present before reboot? 3 ccr??? Can you attach net scheme ?
I remember some users complaining when pppoe server reaches some limit threshold (don’t recall now exactly), probably I’m wrong but maybe worth to search in old topics also..
When CPU load increases to 90-100%, FAN speed is about 25000RPM. In profile it shows queueing consumes 70-80% CPU. This setup was working fine for more than a year and of late we are seeing this issue.
We have same setup for more than a year working fine. We didn’t notice high cpu usage in queueing. We have several CCRs deployed with same configuration except IPs.
Don’t understand what is causing high cpu utilisation by queueing.
If these rules are not working as expected, could you please let us know the rules to block UDP flood.
I have similar issue previously with the bad power supply on CCR1036. The voltage drop below 14volt when the CPU load increase. And subsequently it will reboot automatically.
Take a look of ur power voltage when it CPU load surge.
