Hi Guys
Wanted to check if anybody else is having this problem of SNMP not working even when using default public settings with no authentication.
See below the settings on my router as well as a the SNMP log on the mikrotik showing no errors or authentication failures. I cannot pull SNMP information and i need this for billing purposes.
Any help or advise would be much appreciated.
Source = 172.30.100.16 (My gateway router)
Destination = 172.30.100.254 (My edge router)
Note: I have not firewall rules blocking snmp (udp/161). I have even added a UDP 161 accept rule at the top of my firewall to ensure its not causing a problem
