Hi!
After upgrading my CCR-1016-12s-1s+ RM to version 6.42.6 it is stuck on “starting kernel”.
Net install is not working.
Tried the net install setup with a different router, and it works.
But this particular router is not showing up in the Netinstall router list.
Did you try ether12 for netinstall?
And is there any special routerboot setting that would prevent the netinstall?
Well, you solved it using serial… at least that is an option on that device.
