Just noticed that one of my CCR’s (CCR1036-12G-4S) doesn’t display the temperature properly.
Basically got two exact same model CRRs on same firmware (3.39) and ROS 6.38.7 and the problematic one shows:
> system health pr
fan-mode: auto
use-fan: main
active-fan: main
cpu-overtemp-check: yes
cpu-overtemp-threshold: 100C
cpu-overtemp-startup-delay: 1m
voltage: 24.2V
current: 1441mA
temperature: -45C
power-consumption: 34.8W
fan1-speed: 3099RPM
fan2-speed: 3164RPM
The other that is working fine:
> system health print
fan-mode: auto
use-fan: main
active-fan: main
voltage: 23.7V
current: 1249mA
temperature: 42C
cpu-temperature: 53C
power-consumption: 29.6W
fan1-speed: 3331RPM
fan2-speed: 3331RPM
Any ideas?
The problem was present on 6.37.5 as well.
