CCR TO CCR connection with pppoe Server and static IP
Please help me as soon as possible see the diagram …
Sent from my Mi A3 using Tapatalk
Mikrotik experts please help i need that solution very urgently.
Looking at your diagram I can only guess:
103.88.88.13/30 is the transport network between ccr1 and ccr2
ccr2 has a default route pointing to ccr1
103.88.88.1/29 is hosted on ccr2 and ccr1 should be able to talk to 103.88.88.1
Let’s assume:
ccr1 has 103.88.88.13/30 and ccr2 has 103.88.88.14/30 of the transport link
if my ccr2 default route assumption mentioned above is correct, all you have to to is this on ccr1:
/ip route add dst-address=103.88.88.1 gateway=103.88.88.14
# or, if you want to cover the whole /29 network:
/ip route add dst-address=103.88.88.0/29 gateway=103.88.88.14
-Chris
Thank you Sir for your reply,
Yes i got internet in CCR 2 … But
It’s taking 103.88.88.14
I want 103.88.88.1 it’s live IP..
Is getting the address from CCR1’s dhcp server?
If so, make the lease static, adjust the address and let CCR2 renew the lease.
If it’s static on CCR2, first add it to to correct interface (which then has .14 and .1), adjust all routes and peer settings in both routers accordingly, then remove .14
-Chris
Solved.
Thank you Sir [emoji106]
