CCR update fail 6.27 - 6.29.1
I can not update the device from version 6.27 to 6.29.1
I tried to remove all files from the disk and load the new version. I tried to update the section System - Check for update, but in any case the device after the restart remains with version 6.27.
 > system package update upgrade
  current-version: 6.27
   latest-version: 6.29.1
In addition, I can not manage packages from the System - Packeges. I’m trying to turn \ disable any package, but after restarting it remains in the same state.
> system routerboard print
  routerboard: yes
  model: CCR1036-12G-4S
  current-firmware: 3.22
  upgrade-firmware: 3.22
 /system package> print
Flags: X - disabled
 #   NAME                    VERSION                    SCHEDULED
 0 X gps                     6.27
 1   ntp                     6.27
 2   ppp                     6.27
 3 X ups                     6.27
 4   dhcp                    6.27
 5 X ipv6                    6.27
 6 X mpls                    6.27
 7 X hotspot                 6.27
 8   security                6.27
 9   advanced-tools          6.27
10 X calea                   6.27
11 X user-manager            6.27
12   system                  6.27
13 X openflow                6.27
14 X wireless                6.27
15   wireless-fp             6.27
16   multicast               6.27
17   routing                 6.27
before update:
file print
 # NAME                    TYPE                         SIZE CREATION-TIME
 0 openflow-6.29.1-tile... package                  160.1KiB jul/06/2015 03:04:45
 1 ppp-6.29.1-tile.npk     package                  428.1KiB jul/06/2015 03:04:45
 2 routeros-tile-6.29.1... package                   16.0MiB jul/06/2015 03:04:55
 3 routing-6.29.1-tile.npk package                  196.1KiB jul/06/2015 03:04:55
 4 security-6.29.1-tile... package                  512.1KiB jul/06/2015 03:04:55
 5 system-6.29.1-tile.npk  package                   12.1MiB jul/06/2015 03:05:02
 6 ups-6.29.1-tile.npk     package                  140.1KiB jul/06/2015 03:05:02
 7 user-manager-6.29.1-... package                 1120.1KiB jul/06/2015 03:05:03
 8 wireless-6.29.1-tile... package                 1124.1KiB jul/06/2015 03:05:03
 9 wireless-fp-6.29.1-t... package                 1216.1KiB jul/06/2015 03:05:04
10 advanced-tools-6.29.... package                  192.1KiB jul/06/2015 03:05:04
11 calea-6.29.1-tile.npk   package                   88.1KiB jul/06/2015 03:05:04
12 dhcp-6.29.1-tile.npk    package                  292.1KiB jul/06/2015 03:05:04
13 gps-6.29.1-tile.npk     package                   84.1KiB jul/06/2015 03:05:04
14 hotspot-6.29.1-tile.npk package                  288.1KiB jul/06/2015 03:05:04
15 ipv6-6.29.1-tile.npk    package                  360.1KiB jul/06/2015 03:05:05
16 mpls-6.29.1-tile.npk    package                  168.1KiB jul/06/2015 03:05:05
17 multicast-6.29.1-til... package                  144.1KiB jul/06/2015 03:05:05
18 ntp-6.29.1-tile.npk     package                  376.1KiB jul/06/2015 03:05:05
19 autosupout.old.rif      .rif file                745.2KiB jul/06/2015 03:12:55
20 autosupout.rif          .rif file                745.6KiB jul/06/2015 03:20:39
after. Pay attention to file extension - npk or package.
> file print
 0 routeros-tile-6.29.1.npk        package        16.0MiB jul/06/2015 03:04:55
 1 autosupout.old.rif        .rif file        745.6KiB jul/06/2015 03:20:39
 2 gps-6.29.1-tile.npk        package        84.1KiB jul/06/2015 03:32:35
 3 ntp-6.29.1-tile.npk        package        376.1KiB jul/06/2015 03:32:36
 4 ppp-6.29.1-tile.npk        package        428.1KiB jul/06/2015 03:32:36
 5 ups-6.29.1-tile.npk        package        140.1KiB jul/06/2015 03:32:36
 6 dhcp-6.29.1-tile.npk        package        292.1KiB jul/06/2015 03:32:37
 7 ipv6-6.29.1-tile.npk        package        360.1KiB jul/06/2015 03:32:38
 8 mpls-6.29.1-tile.npk        package        168.1KiB jul/06/2015 03:32:38
 9 hotspot-6.29.1-tile.npk        package        288.1KiB jul/06/2015 03:32:38
10 security-6.29.1-tile.npk        package        512.1KiB jul/06/2015 03:32:39
11 advanced-tools-6.29.1-tile.npk        package        192.1KiB jul/06/2015 03:32:40
12 calea-6.29.1-tile.npk        package        88.1KiB jul/06/2015 03:32:40
13 user-manager-6.29.1-tile.npk        package        1120.1KiB jul/06/2015 03:32:41
14 system-6.29.1-tile.npk        package        12.1MiB jul/06/2015 03:32:43
15 openflow-6.29.1-tile.npk        .npk file        160.1KiB jul/06/2015 03:32:43
16 wireless-6.29.1-tile.npk        .npk file        1124.1KiB jul/06/2015 03:32:44
17 wireless-fp-6.29.1-tile.npk        .npk file        1216.1KiB jul/06/2015 03:32:45
18 multicast-6.29.1-tile.npk        .npk file        144.1KiB jul/06/2015 03:32:45
19 routing-6.29.1-tile.npk        .npk file        196.1KiB jul/06/2015 03:32:46
Why do you have ALL the packages installed? Disabling doesn’t free up space, actually uninstall all of them first.
I have no problem with the free space on a disk, I have a problem with the update ROS.
In addition, there is one more CCR device with version 6.23, which is also not updated to version 6.29.1.
If I remove the extra packages, that will help me to upgrade to the required version of me?
I can not remove the disabled packages. after rebooting packages that were marked to remove remain in disabled state.
It is never a good idea to install all packages. Some packages can even conflict (like the big routeros package and individual packages, or multiple types of wireless packages).
use Netinstall to recover your device
This is a good developer’s reply - do not install something of what we develop, because there may be conflicts. And where is this warning on download page? or in packages archives?
And very competent advice: reset the device and reinstall it via NetInstall. You sell SOHO routers or CCR is this carrier grade solution?
The reason for the packages that cannot be removed is most probably the combined package used for install. Downgrade or update with selected individual packages only. Don’t install anything you don’t need.
I have tried different variations of the files. only the main package, only additional packages, the sum of these packages - the result is always the same. I can not remove the extra packages, I can not turn them off. device does not respond to my action.
Now I’m trying to make export settings to a file
export file=bla
and the export process stops. Appears on the disk file with the extension .in_process and its contents are not complete device settings.
I tried to make netinstall on the test device with the option Keep Old Config. And the device has been updated without saving.
very nice solution to the problem? update your device and get the device with factory settings without the ability restore settings?
