CCR1009-7G-1C-1S+ Maximum Address-List size
Wondering what the maximum items which can be populated within an Address-List. We currently have over 133,000 items and now when working within terminal I get kicked from Winbox and find that the terminal session had ended. Using Winbox v3.12, memory holds fine at 1.6G, CPU stays around 1%, v6.40.5.
How do you connect to a mikrotik, via AC or via IP ?
This particular router Winbox via IP through a GRE Tunnel running IPSec.
The limit for actual usage of the list will probably be much higher than for the management via winbox etc.
You can use filtering in winbox to limit how many entries you see at the same time.
