CCR1009-8G-1S-1S+ - 2 network wired and wireless
hi there how can i do 2 networks on this router CCR1009-8G-1S-1S+
port 5 and 6 bridge for wireless
172.16.0.0/24
port 7 and 8 bridge for network LAN
192.168.3.0/24
1 to 4 ports are for WAN
as of now 1 wan is used
192.168.254.254 ip of MODEM
ip of mikrotik is 172.16.0.1
how to do it that the LAN has internet, thanks a lot
You might want to change the ports a little.
Eth1 - Eth4 are on a switch - you’ll have best results using these with VLANs for the LAN and the Wireless portions of your network.
Use Eth5 - Eth8 for the WAN ports.
Since you have one internet connection for now all you need to do is add a default route to the traffice genreated on the LAN and Wireless networks.
