Hi
I’d like to enable the web proxy on this device in order to log user browsing data
I’d like to use a compatible (flash device) MicroSD or USB key that has enough space to handle this
I don’t think there would be a great difference in speed between MicroSD or a USB key; am I right ?
I purchased a MicroSDHC SanDisk Extreme Plus 16 GB, Class 10, U3 but this doesn’t appear in the system disk list of devices
Could you suggest a manufacturer and model that you have already successfully used ?
thanks
yann
