CCR1009-8G-1S-1S+ General info & Questions
Hello there,
I have the same device. I cannot reach the device via network. What kind of cable should I buy to connect to the console port with a computer? Female console to Rs232?
If you have a rs-232 port on your computer, a common null-modem one will do.
Reference is here:
https://wiki.mikrotik.com/Manual:Null_modem_cable
https://help.mikrotik.com/docs/spaces/ROS/pages/328139/Serial+Console
There is also a serial header on that model.
