CCR1009-8G-1S-1S+ how to monitor dual power supply?
Happy 2015!
I’ve a question about CCR1009-8G-1S-1S+…
How can I monitor/check the dual power supply status?
I’ve not found a menu/alert/led/other to check/notify me if one of two power supply is down.
It’s essential for all dual power supply device.
Thanks!
Regards
Did you ever figure this out?
I agree, two power supplies are useless if you don’t know when one dies.
For anyone who cares, you can in fact monitor both power supplies on a CCR-1009-1S-1S+ – it’s right there in system health, also available via SNMP.
/system health print
                    fan-mode: auto
                     use-fan: main
                  active-fan: main
          cpu-overtemp-check: yes
      cpu-overtemp-threshold: 100C
  cpu-overtemp-startup-delay: 1m
                     voltage: 23.8V
                     current: 945mA
                 temperature: 30C
             cpu-temperature: 55C
           power-consumption: 22.5W
                  psu1-state: ok
                  psu2-state: ok
                  fan1-speed: 4638RPM
psi1-state & psu2-state give you the power supply status.
