CCR1009-8g-1s-1s+ PC with performance problems
I have just installed one Mikrotik router to a customer. It is the first time I work with it, so I did some tests here at our office with the CCR1009-8g-1s-1s+ router with any problem.
But today two hours later to install the router on customer premises, they have phoned me because some PCs are having connectivity problems. They receive the DHCP configuration but they cannot access to internet (for example).
Making some pings to the router the situation is very strange, sometimes there is not answer, others we have a big latency with packet loss, and others after a very long ping time we have a normal ping without any packet loss (but with long ping time).
It is like we are having performance problems, perhaps I missed something at the configuration (I copy it bellow).
Please, I need any idea to fix the situation. Thanks in advance.
[admin@MikroTik] > export
jul/10/2015 11:26:12 by RouterOS 6.30.2
software id = 2SIC-ZGP8
set [ find default-name=ether1 ] name=ether1-gateway
set [ find default-name=ether2 ] name=ether2-master-local
set [ find default-name=ether3 ] master-port=ether2-master-local name=\
ether3-slave-local
set [ find default-name=ether4 ] master-port=ether2-master-local name=\
ether4-slave-local
/interface vlan
add interface=ether1-gateway l2mtu=1574 name=vlan3 vlan-id=3
add interface=ether1-gateway l2mtu=1574 name=vlan6 vlan-id=6
/interface pppoe-client
add add-default-route=yes allow=pap,chap default-route-distance=1 disabled=no \
interface=vlan6 max-mru=1492 max-mtu=1492 name=pppoe-out1 password=\
adslppp use-peer-dns=yes user=adslppp@telefonicanetpa
add name=dhcp ranges=10.10.2.1-10.10.3.254
add name=vpn ranges=192.168.3.10-192.168.3.20
add address-pool=dhcp disabled=no interface=ether2-master-local name=dhcp1
/ppp profile
set *FFFFFFFE dns-server=192.168.3.250 local-address=192.168.3.250 \
remote-address=vpn
/interface pptp-server server
set authentication=mschap2 enabled=yes
add address=10.10.1.1/20 interface=ether2-master-local network=10.10.0.0
add address=192.168.100.10/24 interface=ether1-gateway network=192.168.100.0
/ip dhcp-client
add add-default-route=no dhcp-options=hostname,clientid disabled=no \
interface=vlan3 use-peer-ntp=no
add address=10.10.0.0/20 dns-server=10.10.1.1 gateway=10.10.1.1 netmask=20
set allow-remote-requests=yes
/ip dns static
add address=10.10.1.1 name=router
add chain=input comment="default configuration" protocol=icmp
add chain=input comment="default configuration" connection-state=established
add chain=input comment="default configuration" connection-state=related
add chain=input disabled=yes dst-port=23,80 in-interface=pppoe-out1 protocol=\
tcp
pppoe-out1 not ready
add chain=input dst-port=8291 in-interface=pppoe-out1 protocol=tcp
add chain=input dst-port=1723 in-interface=pppoe-out1 protocol=tcp
add action=drop chain=input comment="default configuration" in-interface=\
pppoe-out1
add chain=forward comment="default configuration" connection-state=\
established
add chain=forward comment="default configuration" connection-state=related
add action=drop chain=forward comment="default configuration" \
connection-state=invalid
/ip firewall mangle
add action=set-priority chain=postrouting new-priority=4 out-interface=vlan3
add action=set-priority chain=postrouting new-priority=1 out-interface=\
pppoe-out1
add action=masquerade chain=srcnat comment="default configuration" \
out-interface=pppoe-out1
out-interface=ether1-gateway
out-interface=vlan3
add action=dst-nat chain=dstnat disabled=yes dst-port=80 in-interface=\
pppoe-out1 protocol=tcp to-addresses=192.168.1.125
add action=dst-nat chain=dstnat disabled=yes dst-port=21 in-interface=\
add chain=dstnat dst-address=10.10.1.5 dst-port=554-557 protocol=tcp \
src-address=192.168.100.10
add chain=dstnat dst-address=10.10.1.2 dst-port=3389 protocol=tcp \
add chain=dstnat dst-address=10.10.1.2 dst-port=9191 protocol=tcp \
add chain=dstnat dst-address=10.10.1.9 dst-port=10000-10006 protocol=tcp \
add chain=dstnat dst-address=10.10.1.2 dst-port=1433 protocol=tcp \
add chain=dstnat dst-address=10.10.1.4 dst-port=1000 protocol=tcp \
add distance=255 gateway=255.255.255.255
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=ether2-master-local type=internal
add interface=pppoe-out1 type=external
/routing rip interface
add interface=vlan3 passive=yes receive=v2
/routing rip network
add network=10.0.0.0/8
/system clock
set time-zone-name=Europe/Madrid
/system ntp client
set enabled=yes primary-ntp=163.117.202.33 secondary-ntp=89.248.104.162
/system resource irq rps
set sfp-sfpplus1 disabled=yes
set sfp1 disabled=yes
set ether5 disabled=yes
set ether6 disabled=yes
set ether7 disabled=yes
set ether8 disabled=yes
/system routerboard settings
set cpu-frequency=1000MHz memory-frequency=1066DDR
/tool romon port
add
I have similar issues.
LK
We have the same problem!
We have (possibly) narrowed it down to the dst-nat firewall rule with port 80.
chain=dstnat action=dst-nat to-addresses=192.168.1.243 to-ports=80 protocol=tcp dst-port=80 log=no log-prefix=""
when the rule is ON (active) the router starts having problems in a hour or two. The solution is to disable the rule or change the to-ports number other than port 80. The problems are slow response from the router, very long pings, some websites do not work (we suspect the DNS server and cache)
What can be the problem? DNS maybe?
What settings do you have for www service?
http://192.168.1.1/webfig/#IP:Services
my 1009 has this lines very different
set sfp-sfpplus1 disabled=no
set sfp1 disabled=no
set ether5 disabled=no
set ether6 disabled=no
set ether7 disabled=no
set ether8 disabled=no
we have theese settings for IP services, there is no conflict for port 80.
  • NAME PORT ADDRESS CERTIFICATE
0 telnet 23
1 ftp 21
2 www 8090
3 ssh 22
4 X www-ssl 443 none
5 api 8728
6 winbox 8291
7 api-ssl 8729 none
