CCR1009-8G-1S-1S+ PoE?
Hi.
Can anyone confirm if the ports on this device pass through PoE?
I’d like to run 5 Ruckus APs on this device and I didn’t want to purchase a separate PoE switch to do so if I don’t need to.
Also is this the model with the dual PSUs?
Many thanks
saltrock.
CCR1009-8G-1S-1S+ supports only PoE-input on port Ether8
There is no PoE out but you can use PoE injectors to pass PoE:
https://routerboard.com/RBGPOE
