hi
my ccr stop in loading kernel from nand when i turn it on.i try net install and use 6.30 pakage but router turn on and again reboot .
use ersion 6.10 router dosent reboot but stop in loadin kernel from nand
what should i do for this problem?
Have you tried doing a NetInstall?? I had a smilar issue with a CCR1009-8G-1S-1S+PC - but solved it by reinstalling RouterOS and later partitioning the flash storage into two 64MB slots.
yes i use netinstall but still has problem but didnt do partotioning becuse stop in loadin kernel
Are you using a Serial cable to connect to the CCR1009 ?
It should give you the option to boot from the network to uset NetInstall.
That is how I recovered mine.
i connect to router via consul but i see kernel loading failed too.
then i format nand and repartition.now i have 2 partition
nand size is 128
but no when i plug router on lcd write ether boot and then stop and no action.what should i do?
thanks
Stop the boot process on the console and tell the router to boot from the network and have the net install server ready.
I enabled network boot but net install dosent know router.I tried it but no result
Have you configured the router to boot from the network? You should connect Eth8.
Yes I configured to boot from network and I connect eth8
hi
i boot it from eth and i install ros
but now when i install ros v6.10 i have no problem and router boot but when i install v 6.30.2 router goes loading kernel from nand and stop
do you have any solution for this?
thank you
hello
i have problem when i update my router to new v.now current v is 6.10 and router has no problem but when i update it to 6.30 i see loading kernel from nand and router stop
what should i do?
Bump…
Support? I’m having the same kind of problems on two CCR1036-12G-4S routers. They refuse to boot over ethernet using Netinstall.
Bump…
I did it but has same problem again
#Support, some HELP. Same problem CloudCoreRouter 1009-7G-1C-1S+
NAD FAIL, can write, Try NetInstall, and fail after one min … how to solv these, can i boot fron SD card?
HELP!!!
HELP!!!
