CCR1009-8G-1S-1S+ upgrade to 6.38.1 issue
Upgraded our CCR1009-8G-1S-1S+ to 6.38.1 just now. After it reboots, notice in Winbox there is no system information as there was before. Additionally, there is no ipv6 menu. Downloaded the ipv6 npk file, put it in files, rebooted, still no ipv6.
/ping 2620:0:ccc::2
  SEQ HOST                                     SIZE TTL TIME  STATUS
    0                                                         could not make socket
Also noticed after upgrade, no IpSec menu.
Something not right with the 6.38.1 upgrade?
Downloaded the 6.37.4 (Bugfix only) npk file, added it to files, rebooted, and ipsec is present. In packages, enabled ipv6, rebooted again, ipv6 menu is present and can ping ipv6 addresses.
 /ping 2620:0:ccc::2
    0 2620:0:ccc::2                              56  59 17ms  echo reply
    1 2620:0:ccc::2                              56  59 17ms  echo reply
    sent=2 received=2 packet-loss=0% min-rtt=17ms avg-rtt=17ms max-rtt=17ms
Like to keep our Mikrotik router up to date. Any help with this?
Thanks.
