am already use this router board but i doubt in my configuration can u help me please
i have one Wan 60 MB
need best profile for 150 users per day
and DNS too
mine is
[admin@MikroTik] /console> configration
bad command name configration (line 1 column 1)
[admin@MikroTik] /console> print
bad command name print (line 1 column 1)
[admin@MikroTik] /console> dns
bad command name dns (line 1 column 1)
[admin@MikroTik] /console> ..
[admin@MikroTik] > dns
[admin@MikroTik] > ip
[admin@MikroTik] /ip> dns
[admin@MikroTik] /ip dns> print
servers: 217.139.0.38,217.139.225.250,8.8.8.8
dynamic-servers:
allow-remote-requests: yes
max-udp-packet-size: 2024
query-server-timeout: 2s
query-total-timeout: 1s
i need to make configuration good as i well
thnks all
Are you looking for a complete configuration or looking for pointers?
How are your clients connecting and authenticating with you?
Are you acting as an ISP / WISP or is this an office type deal?
How many users do you expect online at any given minute? (should use queues or mangle rule to distribute total bandwidth)
What is it you are trying to achieve versus what you have now?
first thanks for ur reply
i have from 150 to 180 users in daily basis they connect hotspot
about me I need to improve the service we are a hotel and some of our score depend on Wi-Fi service I got 60 M in one line from one of ISP goid one but I feel I have something missing to reach to good service
if u need to see my configuration I can send it to u
it’s simlpe not have many rules in mangle
At this time I don’t need to see your config.
More Questions:
What is lacking about your current service for WiFi for your clients?
How is your bandwidth managed at the moment? For example are there any limitations on the amount of bandwidth a single user can use?
Is there a certain amount reserved for the hotel itself?
You plan for 150-180 online each day, but roughly how many each minute? You need to manage your over-subscription rate.
For instance:
You could set a queue tree where the total bandwidth is 60Mbps.
Then you set aside 10Mbps for the hotel itself; that leaves 50Mbps for your guests.
At this point you would want to look at how many people are connected at any given moment. Say for instance, during the day, you have on average 50 users connected. At night that would probably be more. You can setup a queue for daytime hours to allocate 5 Mbps with a burst to 10 Mbps per user. Keep in mind not all users at any given moment will use their available bandwidth. Most would be checking email, social media and uploading photos / videos.
If you plan to support streaming features such as YouTube or Netflix you will need enough bandwidth allocated on a per user basis. You would probably want 7-10 Mbps per user to give sufficient support for streaming. You see here that you can quickly run out of bandwidth. This really depends on what your clients are actually using your WiFi for.
What are your clients complaining about in their reviews?
You need to know this in order to know what to prioritize or limit depending on the situation, evalutate your networks (per service) bandwidth allocation and configure preferably queue trees (queue trees use multithreading, simple queues don’t). to give you and idea most websites won’t use more than 2mpbs to load the page, Video Calls use about the same or even less and video streaming will use stable 4mpbs for 1080p with burst of 8-10mbps to populate cache.
thanks again
am not made any queues just create profile and most of them are free quota just limited as
name=“free” status-autorefresh=1m shared-users=2 add-mac-cookie=yes
mac-cookie-timeout=0s rate-limit=“512k/1024k” address-list=“”
transparent-proxy=yes open-status-page=always advertise=no
just it and after i checked here i see
queue trees
