Hello, I have a problem with CCR1009-8G-1S, RouterOS 6.36 (stable).
I have a first connection to ISP over PPPoE (port1), and when I make a second connection to another ISP over PPPoE (port6) and enable this connection - router reboots immediately with kernel failure. Separately, each connection is working well, but if enable 2 connection both, CCR reboots. What’s the problem? Please help.
I use a CCR1009-8G-1S-1S+ and I don’t have a single problem with this device. Never had such a nice router.
Probably you read only messages about problems and no messages about successes?
I solved the problem. On one of PPPoE connection was enable option Dial on Demand. When I turned off this option, CCR is no longer kernal failure.
But this is a bug, I hope this bug will be fixed in future versions ROS.
