CCR1009 and CRS125 with VLANS no dhcp on WiFi, why?
I have a CCR1009 for routing, DHCP, hotspot and usermanagement. I use VLANS. I have also a CRS125 connected to it and use the WiFi on it.
On the CRS125 I have several Virtual AP's and the are connected to VLAN's.
Clients can connect to the Virtual AP but cant get a DHCP address from the DHCP server.
I see an DHCP offer on the CCR1009 but the client did not get the request I think.
Did I miss something in my config?
Do I need to add switch1-cpu to the TAGGED ports for the VLANS on de CRS125?
Below a part of the config in the CRS125.
VLAN 10,20,30,40.50,60 and 900 work ok with DHCP (they are wired ports on the CRS125
For example VLAN 14,19,24,29,34,39,44,49,54,59,64 and 69 are VLAN's for the wireless in the CRS125 and don't work with DHCP now.
Tagged poorten toevoegen (Trunk ports)
/interface ethernet switch egress-vlan-tag
add vlan-id=9 tagged-ports=ether1,ether22,ether23,ether24,switch1-cpu
add vlan-id=10 tagged-ports=ether1,ether11,ether22,ether23,ether24
add vlan-id=12 tagged-ports=ether1,ether22,ether23,ether24
add vlan-id=14 tagged-ports=ether1,ether22,ether23,ether24
add vlan-id=15 tagged-ports=ether1,ether22,ether23,ether24
add vlan-id=16 tagged-ports=ether1,ether22,ether23,ether24
add vlan-id=17 tagged-ports=ether1,ether12,ether22,ether23,ether24
add vlan-id=18 tagged-ports=ether1,ether22,ether23,ether24
add vlan-id=19 tagged-ports=ether1,ether22,ether23,ether24
add vlan-id=20 tagged-ports=ether1,ether11,ether22,ether23,ether24
add vlan-id=22 tagged-ports=ether1,ether22,ether23,ether24
add vlan-id=24 tagged-ports=ether1,ether22,ether23,ether24
add vlan-id=25 tagged-ports=ether1,ether22,ether23,ether24
add vlan-id=26 tagged-ports=ether1,ether22,ether23,ether24
add vlan-id=27 tagged-ports=ether1,ether12,ether22,ether23,ether24
add vlan-id=28 tagged-ports=ether1,ether22,ether23,ether24
add vlan-id=29 tagged-ports=ether1,ether22,ether23,ether24
add vlan-id=30 tagged-ports=ether1,ether11,ether22,ether23,ether24
add vlan-id=32 tagged-ports=ether1,ether22,ether23,ether24
add vlan-id=34 tagged-ports=ether1,ether22,ether23,ether24
add vlan-id=35 tagged-ports=ether1,ether22,ether23,ether24
add vlan-id=36 tagged-ports=ether1,ether22,ether23,ether24
add vlan-id=37 tagged-ports=ether1,ether12,ether22,ether23,ether24
add vlan-id=38 tagged-ports=ether1,ether22,ether23,ether24
add vlan-id=39 tagged-ports=ether1,ether22,ether23,ether24
add vlan-id=40 tagged-ports=ether1,ether11,ether22,ether23,ether24
add vlan-id=42 tagged-ports=ether1,ether22,ether23,ether24
add vlan-id=44 tagged-ports=ether1,ether22,ether23,ether24
add vlan-id=45 tagged-ports=ether1,ether22,ether23,ether24
add vlan-id=46 tagged-ports=ether1,ether22,ether23,ether24
add vlan-id=47 tagged-ports=ether1,ether12,ether22,ether23,ether24
add vlan-id=48 tagged-ports=ether1,ether22,ether23,ether24
add vlan-id=49 tagged-ports=ether1,ether22,ether23,ether24
add vlan-id=50 tagged-ports=ether1,ether11,ether22,ether23,ether24
add vlan-id=52 tagged-ports=ether1,ether22,ether23,ether24
add vlan-id=54 tagged-ports=ether1,ether22,ether23,ether24
add vlan-id=55 tagged-ports=ether1,ether22,ether23,ether24
add vlan-id=56 tagged-ports=ether1,ether22,ether23,ether24
add vlan-id=57 tagged-ports=ether1,ether12,ether22,ether23,ether24
add vlan-id=58 tagged-ports=ether1,ether22,ether23,ether24
add vlan-id=59 tagged-ports=ether1,ether22,ether23,ether24
add vlan-id=60 tagged-ports=ether1,ether11,ether22,ether23,ether24
add vlan-id=62 tagged-ports=ether1,ether22,ether23,ether24
add vlan-id=64 tagged-ports=ether1,ether22,ether23,ether24
add vlan-id=65 tagged-ports=ether1,ether22,ether23,ether24
add vlan-id=66 tagged-ports=ether1,ether22,ether23,ether24
add vlan-id=67 tagged-ports=ether1,ether12,ether22,ether23,ether24
add vlan-id=68 tagged-ports=ether1,ether22,ether23,ether24
add vlan-id=69 tagged-ports=ether1,ether22,ether23,ether24
add vlan-id=900 tagged-ports=ether1,ether11,ether22,ether23,ether24
