Hello
any real experiences of CCR1009 with 7.15.3 (or similar v7) and its handling of 3x FRT?
The v7 is optimized for multi-core BGP.
Assuming we use the affinity to default (I have seen on 1036 and it creates separate BGP processes for each peer, and I didnt have the need to set manually the settings).
Conntrack enabled only for input traffic. (to protect the manangement part, but could be disabled also there and we could use RAW rules).
just some basic RAW firewall settings (very few rules).
Will be the 1009 fast enough to reconverge in seconds, not in minutes ?
Thank you
