I know I can get away with an external PoE injector but I would really like to add PoE out functionality to my CCR1009 -7G-1C-1S+
The device is overkill* for my purposes but after upgrading my home internet connection to 1000/300Mbit my HEX PoE can’t keep up.
I’m thinking about soldering a PoE injector onto the board without compromising the redundant power supply. I There are unused JL401 and JL404 pads for connectors on the board but they are only connected to POWER2 so no redundant option. Has anyone tried a mod like this before and figured something out? ![]()
I made some photos od the board with my phone but they are not good so I’ll try a better camera later.
*the only reason I want to use it instead of something else is that I got it real cheap ![]()
