CCR1009 netinstall not working
I have a flaky CCR that I am trying to get running. Every attempt at a netinstall fails. When it looks like it’s trying to do it, it says it’s transferring a file, then running it, but at no time does the unit show up in the netinstall app or ask me what image to install.
No matter what I try, the result is the same. I’ve even gone as far as reflashing the NAND.
Anyone want to see shoot a CCR with a 9mm ??
Here is the output:
RouterBOOT booter 6.44.1
CCR1009-8G-1S
CPU frequency: 1000 MHz
Memory size: 1024 MiB
NAND size: 128 MiB
Press any key within 2 seconds to enter setup..
loading kernel… kernel not found or data is corrupted
trying bootp protocol… OK
Got IP address: 192.168.88.4
resolved mac address D8:EB:97:B3:B8:37
transfer started … transfer ok, time=2.92s
setting up elf image… OK
jumping to kernel code
