Can anyone please recommend the best possible vpn procol type and encyption algorithm that possibly can utilize hardware acceleration on CCR1009 <=> RB3011 (Ros 6.37.4) to obtain maximum VPN performance. They are hooked up with SFP to a 500 Mbit fiber line…
I assume you mean a site-to-site VPN. IPsec is actually pretty light as far as VPN tech goes, but your limiting factor will be your link between the two routers compounded by your underlying encryption. Heavy encryption = more security = slower speeds. So the fastest? Don’t encrypt. But you’ll have to determine if this is feasible with your environment.
Well, of course we want to have encryption. But what I was wondering about is what type of encryption algorithm (e.g. DES, AES, etc) that would be most efficient in terms of hardware acceleration in order to get the highest possible speed without to much load on the main processor on a RB3100 connected to a CCR1009.
According to the Qualcomm specs, the IPQ8064 has support for IPSec hardware encryption but I can’t find any info regarding the RB3011 on the product pages or wiki…
According to that link above, only the following have encryption hardware offload capabilities, and then only for AES:
hEX v3 (RB750Gr3 model only)
All Cloud Coure Router series devices
RB1100AHx2
RB1000
RB850Gx2 (only starting 2016, serial numbers that begin with number 5)
So if I understand it correctly, by using HW acceleration on a CCR you may instead encounter a reorder problem? Yay! Unfortunately I didn’t find anything on the RB3011…
I don’t think the RB3011 supports hardware acceleration but you will need to pick encryption mentioned in that thread for the CCR to prevent the re-ordering problem. The CCR tops out around 250Mbit with the software encryption. I’m not familiar with the RB3011 but it may be that is plenty to keep up with it.
Looks like AES128 might be a good choice since the RB3100 currently can’t utilize the hardware accelerator. But it remains to see if it can cope with “soft” IPSec at sufficient speed.
I must say I’m a bit surprised they didn’t implement the hw accelerator. But it’s totally my own fault I didn’t properly investigate the facts, nor did I care to check with sales before we bought a bunch RB3100. The only thing I bothered to do was checking the hardware specs for IPQ8064! There is a lesson there, right?
