i have a problem with capsman. i’ve got a CCR1009 with capsman running.
i want to use 3 SSID’s. Two SSID’s are running. 1 Master / 1 Slave ( virtual ). When i add the second Slave, all connections where killed and then the cap will not work
Defnitely a misconfig, would be usefull to have an export (if you want to continu the CAPsMAN route):
/caps-man export file=anynameyoulike
From an admin perspective I would use CAPsMAN, especially on being able to monitor all wirelles devices in one place. But there are enough reasons to stick to stand alone configs.
