CCR1016-12G always has a core of 100%
Hello everyone, my ccr1016 can not balance the use of 16 cores, semre has one that is 100% this has caused me some problems, I would like to know if there is any solution to the problem.
The scenario this as follows: 02 sessions bgp fullroute one bonding interface and 1GB traffic approximately firewall and quee disabled.
I thank you for your attention!
BGP can only run on one core currently. They are working on that for 7.x, I think they may still be stuck with one core, but they are improving how long it takes to process a full feed. There is nothing you can really do about that part.
I’m not sure about the bonding part either, if that will be loaded across cores or not. If you look at /tools profile it should give you an idea of what process it taking up all the CPU time.
You can also always contact support@mikrotik.com and they can help you with specific configuration issues.
In this case there should be a notice advising of such problem, specifically acquired the hardware for this and the worst bought a ccr-1036 that has the same problem.
