CCR1016-12G ERROR: could not format partitions
Hi guys
Maybe someone had a similar problem. The CCR1016-12G device is immediately loaded in recovery mode, the loader does not see NAND memory (defined as 2048 MiB when physically installed on 4096 MiB), when trying to restore via NetInstall, it immediately throws an error ERROR: could not format partitions, replacing NAND memory with obviously working memory did not give a result, have you ever encountered this kind of malfunction?
Maybe similar problem. The CCR1036-12G-4S device is immedi
