Hello Folks!
We have had problem with CCR1016-12G from the start, two years back.
It simply stop working without further notice, there is nothing in the logs and no supout files, it just stops, all lamps are on like usual, you ca not see anything unusal from outside.
A power recycle by removing power from it and on again helps, then it comes up again as normal and will continue work for some time.
It stops working about one time per second month or so, sometimes more frequent sometimes less frequent.
Anyone else who have the same experience from CCR family, and any idea what it is about, hardware problems ?
There are other mt and cisco devices in that dataroom, they are rock solid, it never happen anything with them, just the CCR has problems.
