ccr1016-12g ram upgrade question
Hi!
I want to increase the amount of RAM in my ccr1016-12g router.
From the tech specifications (https://i.mt.lv/cdn/rb_files/1539732362ccr-16G-series-qg.pdf) I see, that ccr1016-12g use 2x 1GB 10600 modules installed.
My question is - Do I need to install ONLY memory with 10600 - 1333 modules, or router also can work with 12800 - 1600 DDR3 modules? Anyone had such experience? Or I should use only 10600 - 1333 modules?
