CCR1016-12S-1S+ problems with SFP's
Yesterday I got Routerboard CCR1016-12S-1S+ and I had problems with SFPs.
I am trying connect MT with HP 5900AF switch. These SFPs working with HP swiches. Yesterday also tested these SFPs to connect CCR1036-12G-4S with HP 5900AF and it worked. I tried Connect two MT beetween CCR1036-12G-4S and CCR1016-12S-1S+ also worked with same SFPs.
In CCR1016-12S-1S+ i tried to disable autonegotiation, and add 1000 speed with full duplex and link led change to green. But no luck in HP side. Also in HP side i make changes the same i manual change port to 1G and add full duplex. But no luck.
I dont understand with HP those SFPs works fine.
Also MT was updated to 6.20 version.
Can someone Help with advice?
Thank YOU.
