I have a ccr that will not load and giving me the Kernal Loading Failed Message. I tried reloading with netinstall however I cannot establish Ethernet connectivity. Unit was reformatted and repartitioned. How can I get this working again
Which is the actual ROS version on the CCR?
Check (if possible) that firmware is up to date prior to netinstall.
If netinstall fails, it is advisable to try with the same, or next following ROS version, and update firmware prior to trying to update to more recent ROS versions.
