Has anybody had any success with a Fiberstore long range fiber 10 gig module (10GBASE-ZR 1550nm) in the CCR1016? I’m working on a new 10 gig link from my provider and I have good light, but can’t get link. On the interface screen, the router recognizes the module, but the status (RX/TX power, volts, temp, etc) is only updated once when the module is inserted (not periodically). I’ve used several other Fiberstore modules without issue.
As a temporary workaround, I have a 10 gig switch between my router and the provider. The module works in that switch, but obviously I don’t want that to be the permanent solution.
Second question - if it doesn’t work in the 1016, is there any chance it would work in a 1072?
thanks
jim
