CCR1016-12S-1S +. Small byte frame loss...
Good afternoon, colleagues! We have a router CCR1016-12S-1S +. The problem is that, in the routing mode observed packet loss. Testing was conducted on packages in length from 64 to 1518 bytes. The results are attached. Testing was conducted on optical SFP modules Smartbit device. Results in the application. There is loss of packets up to 1000 bytes. Then, there are no losses. Flow will be from the address 192.85.1.2/24 to 192.85.2.2/24. Testing conducted UDP packets.
supout.zip (233 KB)
001.zip (47.8 KB)
Hello!!! Can you help me?
