CCR1016-12S-1S+
“available in April”
can i get a more exact release date?
(read: can i hope to get one of these in april 2014?)
Yes, you will
If it will be available in April, it will be nice :slight_smile:
CCR1016_12S_1S_plus.pdf (341 KB)
http://routerboard.com/CCR1016-12S-1Splus
how much RJ45 SFP coper module for CCR1016-12S-1S+ ?
you get 1 module for each router purchase. And it comes bundled with the router.
if you need all copper, we have other CCR models for that.
Please, add S-RJ01 to your product portfolio. A 10GbE version would also be nice.
I would strongly endorse adding this to the product list.
This is incredibly useful item to be able to have, I know we get one with each shipped but being able to hold a stock of them would be incredible.
A lot of our network is moving to a core that maintains mostly fibre links to other sites and this model would be great but we then have a couple of customers in the POP Site building or we host local setups for the customers and being able to set two or three ports to copper to do that.
Regards
Alexander
a block diagram please, if someone has it at hand.
just checked, the 36 core CCR has one @ routerboard.com.
checked the plain 1016, but it only links to the 1036 version.
It is the same (all ports directly go to CPU). the only difference is the CPU
thx a lot.
First video on youtube → CCR1016-12S-1S+
http://www.youtube.com/watch?v=_LrgWRlS4w0
I’d also like to see S-RJ01 being available as a seperate option. All of our switches use SFP which is why we want this model but our ongoing carrier still presents an RJ45 connection for the main and backup lines so therefore we need 2 x RJ45 connection.
Aside from that, I just like Mikrotik’s SFPs in general and we don’t just use them on Mikrotik devices. I find the Mikrotik ones work as well as the original manufacturer’s and are a fraction of the price (I’m looking at you Cisco and D-Link)!
we successfully tested mtik’s DA cables with Cisco’s Nexus 7k and 5k series switches.
they are recognised as 10Gbase-unknown, but they still work.
CCR1016-12S-1S+ have two power supplies.
How to remotely identify the faulty one?
i’m sure there must be something in “/system heath” menu that you can use.
There is nothing special for two power supplies
Hello.
Where to see failure of 1 supply?
There is nothing in system health
Dual PSU stats will be added in a software upgrade
