CCR1016 BGP ignore AS path
CCR1016 ROS 7.15.3(ROS 7.13 no changes)
  1. ROS ingores AS path and choose 2 routes.
  2. It looks like BGP ECMP, but status of BGP multipath feature is N/A.
    There is no issue on CCR1036 with same configuration and same version.
Set BGP properly so that all sessions run on the same BGP instance.
It is.
It is.
A remote address and/or common template does not mean that the session runs on the same instance. See documentation for more info:
https://help.mikrotik.com/docs/display/ROS/BGP#BGP-RunningMorethanOneInstance
It helps. Thank you!
