ccr1016 + ros6rc7 = no metarouter ?????
Hello
We have upgraded our core network with several ccr1016
ROS on them v6rc7
I can’t see metarouter.
Where is it ? How to enable it?
If not available yet, will it be available in future release ?
Metarouter is not supported at the moment. I can’t say for sure when this will be made. It will take a few versions most likely
so from your words i can think that it will be implemented in some v6 release anyways.
great.
thanks.
Yes
What is the forecast for launch version with MetaRouter to CCR?
Qual a previsão para lançar a versão com MetaRouter para CCR?
as normis explained previously - precise data is not known when feature will be available.
