Hi , this is my question , The best option in your opinion ?
a CCR1036-12-4S
or a PC Server , Eight Core , with 8 GB in Ram .
Thanks .
a CCR1036-12-4S
Thanks .
Do you need extra ports?
you want to use it for what ? PPPoE server, hotspot server , routing… etc ?
and what is the no. of users that you have ?
If you would need to add 4 SFP ports and 12 server quality NIC cards to that server, price difference would be huge.
Like others have asked, some more info is needed to answer your question
this is CCR1036-12-4S
only 2 queue tree for shaping TX (Max limit 290Mbit) and RX (Max limit 290Mbit). CCR is droping 50% packets and packet lost in forwarding in use queue tree. (watch difference between ether1 RX and ether2 TX). CCR was exchanged for intel xeon and everything is ok. CCR is bad. Small performance per core. Wrong way.
Thank you very much , i have 3 another questions here in the forum , but no answer at all .
This is what i need .
Hi , i have a Router OS in a Quad Core Xeon Server with 4 GB Ram , but i have problem with queues , i need several queues , like :
/queue simple add dst-address=110.0.0.0/8 max-limit=256000/256000
The server that i m using is rebooting when i use queues , i dont know , but i think that is CPU usage .
So i need to know if the CCR1036 will work fine with the Queues , or know a good server configuration to do that .
What i need to do , is limit Bandwith used in Countrys like China or Japan .
Is for a Data Center that trafic permanently 50000 Packets per Second , and 500 MB per second .
What is the best solution ?
My example is from the data center. For flow limitation or restriction DDOS is absolutely useless. SQ was also used with the same poor result. Sometimes i have random reboots. Currently used Intel Xeon X5500 quad code, two sockets. No problem.
I recommend Xeon E3 or E5. For example, from Supermicro.
The problem is that the CCR has little power per core. Always the case as one ethernet uplink and one gets confused. Mikrotik can not effectively spread between 36 slow cores. Actually, it always walk away with one core as the recipient of packets from one Ethernet.
Hapi, do you still have it? Many issues were addressed in v6.1 and also now in v6.2 (not released). If you could try these versions, it would help us improve the situation. Also it would be great if you could send your supout.rif file from v6.1 to support, so we can see what configuration you have
ASUS P8P67 WS Revolution + Core i7 + Some quality Intel i350 cards would be the best solution for PPPoE server. We had around 3000 dynamic queues (pppoe users) on one machine, CPU is below 20% but there is problem with router os and we splited it into multiple pppoe servers. It would be great if you can make one pppoe server per 500 users. Mikrotik cant handle more than that.
I can not go back there. It has to work hard. All previous RC versions do the same, I doubt that anything will change v6.1.
Have you repaired the problem with the bridge on the CCR and X86? Just create a bridge interface and see what happens.
What are you talking about??? I use bridge a lot, everything works fine.
About load distribution over CPU cores, you need to realize that not all things can be distrusted, for example layer-7 filter - you need all packets of matching stream under control of single core, so before spreading panic, post your configuration
I usage only 2 QT and 2 Mangle. Other is default. No filter, no nat, no everything other.
Either something specific in those rules, or some setting you are not aware of. Show us your rules
/export compact
DDOS in forwarding on servers. CCR is only forwarding. Without rules. ONLY FORWARDING ABOUT 300.000pps. CCR si unavailable. After switching off the QT to CCR was better but was still unavailable.
This picture is not DDOS. Only forwards UDP test on a different machine. Incoming 66kpps but outgoing only 33kpps!!! 50% packet lost!!! Where is 24Mpps? Where is only 1Mpps? Only 33kpps? Baaad!!!
This is only usage code. CCR can not handle forward through one QT. Low performance peer core!! Bad CCR. This is not use for heavy load.
/ip firewall mangle add action=mark-packet chain=forward in-interface="ether1 - wan" new-packet-mark=download out-interface=ether2 passthrough=no
/ip firewall mangle add action=mark-packet chain=forward in-interface=ether2 new-packet-mark=upload out-interface="ether1 - wan" passthrough=no
/queue tree add limit-at=290M max-limit=290M name=download packet-mark=download parent=ether2 queue=manual
/queue tree add limit-at=290M max-limit=290M name=upload packet-mark=upload parent="ether1 - wan" queue=manual
what is “queue=manual” ???
what does /tool profiler shows ??
I know? This is “compact export”.
I know? After switching off the QT(SQ) is throughput ok.
This is not the full compact export, just two lines.
OMG
/queue tree export compact
there are only two lines!! ONLY TWO QT IS USAGE. How many times did I say?
command is following:
/export compact
please see above and write exactly as written, don’t invent other commands
set 0 name="ether1 - wan"
set 12 auto-negotiation=yes
set 13 auto-negotiation=yes
set 14 auto-negotiation=yes
set 15 auto-negotiation=yes
/port
set 0 name=serial0
/queue type
add kind=sfq name=sfq sfq-perturb=1
/queue tree
add limit-at=290M max-limit=290M name=queue1 packet-mark=download parent=global \
queue=sfq
add limit-at=290M max-limit=290M name=queue2 packet-mark=upload parent=global \
queue=sfq
/snmp community
set servers=8.8.8.8,8.8.4.4
set enabled=no
/ip settings
set secure-redirects=no send-redirects=no
/ip firewall mangle
add action=mark-packet chain=forward disabled=yes in-interface="ether1 - wan" \
add action=mark-packet chain=forward disabled=yes in-interface=ether2 \
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
/lcd
set current-interface="ether1 - wan" read-on
/lcd interface
set 0 disabled=yes
set 1 disabled=yes
set 2 disabled=yes
set 3 disabled=yes
set 5 disabled=yes
set 6 disabled=yes
set 7 disabled=yes
set 8 disabled=yes
set 9 disabled=yes
set 10 disabled=yes
set 11 disabled=yes
set 12 disabled=yes
set 13 disabled=yes
set 14 disabled=yes
set 15 disabled=yes
/snmp
set enabled=yes trap-community=public
/system clock
set time-zone-name=Europe/Prague
/system ntp client
set enabled=yes primary-ntp=195.113.144.201
/system routerboard settings
set cpu-frequency=1200MHz memory-frequency=1
/tool bandwidth-server
set enabled=no
/tool graphing interface
add
/tool graphing resource
add
… is manual hide
