CCR1036-12G-4S interface limit
From my ISP i get 500Mbps
I have a CCR1036-12G-4S running a pppoe server.
I have a bridge interface running on two sfp port and pppoe server is on ether1
How can i limit wan interface to 200Mbps,
I dont find ethernet tx/rx limit.
I try with /interface ethernet switch ingress-port-policer
but command is not for this board.
can anyone help
Have you tried the queueing?
yes i tried. but there is a problem.
I have a radius server for authentication and when a customer authenticate a simple queue is added dinamically from radius server and a pppoe-client interface is added on the interface menu.
when i add a simple queue for the wan interface (TOTAL LIMIT) and set this on top of the others queues that are created automatically from radius, this queue (TOTAL LIMIT) works but the clients are not queue for their bandwidth.
try Global total for you wan interface along with Total Limit as without total limit Global policy can not work.
put a low end mikrotik as a switch
