CCR1036-12g-4s Memory Leak
Dear Team
Few days ago i noticed that my CCR is only having 300 Meg of Memory left out of 4 Gig of Total Memory, which was really shocking, as we are running only 100 users over it and 200 Megs of bandwidth. Not sure exactly from when it is started but about a month ago I add a firewall rule in Mikrotik to redirect the customers log to Kiwi Log Server. It was only 38 days of the uptime and the Free memory was now at 300 Megs. I tried all the possible ways but it was same, so I had to restart it and Boooommm now it was showing 3500 Megs of Free Memory.
Noticeable thing is this that it is loosing 100 Megs within 24 Hours. The ROS was 6.45 on it and on the safe side I tried to upgrade it and now it is having 6.46 but its been 1 day uptime and it is still doing the same. Kindly help to solve the problem, otherwise thinking to downgrade the ROS to some stone age.
My guess is that this will be hard to fix here if it is a mem leak.
Take a supout file, when you can se the problem, and send it to support@mikrotik.com and they can have a look at it.
If you want someone here to be able to help please run /export hide-sensitive and post the output here after you read it and removed other stuff you might not want to show on a forum.
