CCR1036-12G-4S: One subnet on different ports
I have a CCR1036-12G-4S with three Hosts for virtual machines directly connected to it (ether4, ether5, ether6).
All virtual machines are in subnet 10.142.46.128/25 and machines are regularly moved over the hosts.
Because the CCR is missing a switch chip, I use a bridge over these three ports at the moment. But this way of course I have all the traffic on each port.
I guess a CCR is not really the right hardware for connecting servers directly but at the moment I have no dedicated switch for this. Is there a better solution for this? I don“t want to cange routers configuration/routing on each move of a VM.
Regards
Martin
the CCR can switch on wirespeed. It does not however give traffic out of all 3 ports unless it is broadcast. A bridge is limited by virtual resource not physical ports.
So what do you think is the recommended configuration for this setup?
