CCR1036-12G-4S - problem
hi
I have CCR1036-12G-4S probably after hacking. After turning on the power does not start, the console shows:
RouterBOOT booter 3.10
CCR1036-12G-4S
Authorization: failure
I managed to do Netinstall - the problem is still the same, can anyone help?
When start Console I have:
RouterBOOT backup booter 3.22
CCR1036-12G-4S
CPU frequency: 1200 MHz
Memory size: 16384 MiB
NAND size: 1024 MiB
Press any key within 2 seconds to enter setup
RouterBOOT-3.22
What do you want to configure?
d - boot delay
k - boot key
s - serial console
n - silent boot
o - boot device
f - cpu frequency
a - memory frequency
r - reset booter configuration
e - format nand
w - repartition nand
g - upgrade firmware
i - board info
p - boot protocol
b - booter options
x - exit setup
but after netinstall I have:
Waiting for installation server…
Found server at D8:CB:8A:37:89:A5
Formatting disk…
installed routeros-tile-6.46.3
Writing configuration…
Software installed.
Press ENTER to reboot
Rebooting…
Restarting system.
Resetting chip and restarting.
CCR1036-12G-4S
Any Ideas ?
