CCR1036-12G-4S with S+DA0001 Direct attached cable
I have 2 CCR1036 12G 4S routers they are now connected with 2 bonded ether interfaces. If I would connect them with S+DA0001 cable how much throughput could I expect? Modules on those cables support 10G connections, but CCR doesn’t have SFP+ ports, only SFP. I read that SFP can support up to 4.5G, so if anyone can confirm actual speed.
Since you don’t have the 10 gig SFP+ version, the most you can group together and use would be 8 Gbps (8 x 1 Gbps links in a bonding channel)
You can typically bond up to 8 links together an an LACP bonding channel (802.3ad)
While this will give you redundancy and 8 gig of aggregate throughput, you will still be limited to a single TCP/UDP stream size of 1 Gbps since that is the largest single link size in the LACP bond.
How much would I get on single connection on SFP port on CCR1036 router?
1 Gbps
