hi guyz, i just bought ccr1036 12g 4s router, pls is it possible to use 2 isp on it at the same time
I am using 4x ISP (adsl, vdsl, cable and fiber) on a ccr1036, runs very smooth.
Theoretically you can use an almost unlimited amount of ISP’s. But practically it is limited by ethernetports and/or VLAN’s.
pls how can i do that (using 2 isp on 1 router)
There are a lot of examples on how to use multi-wan configs.
It is not easy to do on Mikrotik routers, but if you understand routing/firewall rules and mangle in Mikrotik you will manage to do this.
Please follow this instructions;
http://aacable.wordpress.com/2011/06/04/mikrotik-4-wan-load-balance-pcc-complete-script-by-zaib/#
And just change it from 4x WAN to 2x WAN.
