[ccr1036][6.33][sms]How to initialize SMS GSM modem tool?
use ros 6.33
[m@s] /tool sms> /system serial-terminal serial0 channel=0
[Ctrl-A is the prefix key]
at+cpin?
+CPIN: READY
at+cfun=0
OK
at+cfun=1
OK
at+cpin=1234
OK
at+cpin?
+CPIN: READY
at+gmi
WAVECOM MODEM
OK
at+gmm
MULTIBAND 900E 1800
OK
ati
WAVECOM MODEM
MULTIBAND 900E 1800
OK
at+gmr
532a09gg.2C2 1828120 040802 18:22
at+cmgs=“2222222***”
test
+CMGS: 1
OK
[m@s] /tool sms> send serial0 channel=0 phone-number=2222**** message=go
failure: timeout
What is the solution.
The channels field tells you how many channels are on that port, not the channel number, and the first channel is channel 0 on each port. So there is no channel=1.
You have to use:
/system serial-terminal serial1 channel=0
Or just drop the channel parameter completely (because there is only 1 channel for each port):
hold up
I can use the CLI command line to use channel=0,
But can not open the SMS receiver function, tip: couldn’t change SMS settings- timeout
CLI command line is unable to use channel=1,
Tip: no such channel failure:
SMS receiver function is also unable to use channel=1
/tool sms set receive-enabled=yes
[m@s] /tool sms> send serial0 channel=0 phone-number=2222222*** message=go
failure: timeout
[m@s] /tool sms> send serial0 channel=1 phone-number=2222222*** message=go
failure: no such channel
[m@s] /tool sms> send serial1 channel=1 phone-number=2222222*** message=go
[m@s] /tool sms> send serial1 channel=0 phone-number=2222222*** message=go
failure: timeout
[m@s] /tool sms>
[m@s] > /system serial-terminal channel=0
port: serial0
at
OK
at
OK
AT
OK
test
+CMGS: 1
OK
[Q - quit connection] **[A - send Ctrl-A prefix] [R - autoconfigure rate]
Welcome back!
[m@s] /port> /system serial-terminal channel=1
port: serial0
[m@s] /port> pri
Flags: I - inactive
DEVICE NAME CHANNELS USED-BY BAUD-RATE
0 serial0 1 19200
1 serial1 1 19200
[mf@sys] /port>**
at+cpin?
+CPIN: READY
at+cfun=0
OK
at+cfun=1
OK
at+cpin=1234
OK
at+cpin?
+CPIN: READY
at+gmi
WAVECOM MODEM
OK
at+gmm
MULTIBAND 900E 1800
OK
ati
WAVECOM MODEM
MULTIBAND 900E 1800
OK
at+gmr
test
+CMGS: 1
OK
failure: timeout
hold on
