For some time I have been experiencing a problem with my CCR1036, I cannot delete files, nor can I make backup copies, I can export and copy the files manually and save them in another CCR.
then it goes into Kernel error, I delete partitions, format and mount the system with Netinstall and it works, it works 2 to 3 days and then the same problem.
From what I have read, it is a problem with the Nand or Disk of the CCR.
From what I have investigated, I do not see major comments and much less from the mikrotik team it seems that Tabu was for them to talk about this topic.
I would like to know if this has any solution or do I have to throw away this CCR1036 8G 2S + with 1 year and a half of purchase.
